srxburns
I have a 2000 SRX and it doesn't seem to start as easy as it did last year when warmed up. Before it would start on the first pull now it takes 3-5 pulls and need the choke. Could this be linked to power valves being out of adjustment? Or carbs in need of cleaning? I was told that the Choke plunger might need to be cleaned out.
Clean your carbs and check the fuel screws. Hard starting when warm could be your fuel screws are turned out too far.
