1badz
- Nov 19, 2005
02 Viper. How do I remove the needles so that I can check / change the clip position on the needles
1badz
- Nov 19, 2005
Figured it out! Didn't see the two allen screws on first look.
woolyviper
Careful with that adjustment, one clip makes a pretty dramatic change if you are going leaner.
1badz
- Nov 19, 2005
Thanks,
Just bought the sled and wanted to check the jetting before I ran it. Everything was stock except for the mains being 2 sizes leaner than stock. I'll run it carefully to see if that's OK, everything is too rich from the factories anyway. Two sizes down on my 800 MXZX is perfect
..SNAKEBIT..
2 sizes on a Viper could be lean depending on temperature?
