Secondary sheave Viper S
rather-b-sleddin
Carleton Place Ont.
I recently purchased a 2004 Viper S..My drive belt is sitting about 2 mm below the edge of the secondary sheave. I understand it is supposed to sit 1 mm above the top of the sheave..Adding shims will correct this problem..Can it be done without removing the sheave and if I do this will it throw off my clutch alinement..
take the bolt off holding your clutch on, the clutch will slide right off. on the back side, there's 3 screws- take them out and replace the washers with thicker washers or add some thin ones to the ones you have to achieve your belt height & re-install screws. the further in the screws are, the lower your belt sits.
