Don't have instructions, off set distance for mine.
SRXSex
The team secondary is a waste of time. Talk to Turk.
Thanks for that extremely helpful bit of information. I'm sure it will be usefull in fully optimising my existing clutch setup, you didn't by chance use to own an Arctic Cat did you. It's not very nice of you to be trying to give away Turks extras. I think giving me your own stock secondary would be a far better thing to promise.SRXSex said:The team secondary is a waste of time. Talk to Turk.
kthnxbye
Erik
Turk
TY TECH ADVISER
- May 2, 2003
Don,t get me involved. I briefly played with a team secondary but did not give it any real time to figure it out. I played with it for about 2 hours then returned it to it,s owner. I needed more time to give a fair estimate. It sure was heavy & had lotsa preload tho!
SRXSex
Sorry to all, I am having a frustrating day on my own sled. Apologies to Turk for qouting him.
iahacker
I'm running one on a 700 SRX. Up shifts noticably better than stock and back shifts great riding trails. I keep hearing it isn't any good but, works well other than I noticed the helix hub has been rubing on the frame at full shift out. There wasn't any instructions for off set with mine. Keep an eye out for that. Not what you asked for...just throwing my 2 cents in.
mountain_mod_viper
I'm running one of the new lightweight ones on my 162" viper mod. I like it so far! I was able to get a much stronger bottom than I could get with the stock one. It reacts almost instantly compared to the stock one. The best thing is the shifting characteristics won't change because of buttons wearing down. I used the stock senondary for about 5000 miles and it has worked good for me, but it seemed that everytime I'd put new buttons in it, my clutching would change. The Team also seems to run cooler.
my.02
my.02
B2SO
- Aug 18, 2003
i only have about 50 miles on mine , but like said above , thing is awsome in the trails , back shifts sweet, have not had a chance to see whats going to happen on the long pulss as far as top end i hear thats were the lack , but im a trail rider not a lake racer and as far as i can tell by my butt dyno , works well for my application , as far as the off set , i cut my spacer to 1 5/8 so it wont float anymore and set up the off set to srx specs , but im running the torque stop to ....i would set it up as a stock secondary and shim if needed ....
