98 XT 500 Uneven wearbar wear....
jdmt49
Minnesota
I noticed on my 98 XT 500 that the wearbars are wore out in the front and the back are not even touching the ground. When you sit on the sled you can see the rear of the skis come right off the ground...Any ideas whats going on...the rear suspension looks fine and I have never touched the limiter straps..?
the early sleds with steel skis did that, thats was normal, the ski is just nose heavy, they make a stiffer rubber piece which holds the front of the ski up, The best thing to do though is pitch the skis and go with something else, as far as the tracking issue, thats the skis and the fact that the skis are not aligned correctly are you have loose bushings in the sled
