Bump stops keep pushing out
REDMATER
tya
ny
Website
mysite.verizon.net
98srx:the bump stops on the w arm keep pushing out,what causes this? bottoming out,bad set-up?
also what is a good rear suspension set up for the proaction,this rear suspension is finicky and i would like just a good general set up to work from.
you're pushing the bump stop out only because of bottoming, your center shock is set up wrong, weak spring, or its just bad, maybe, just maybe you pound it down the trail hard, if that is the case you need to increase the compression dampening on that shock..............
