Front shocks - Can I swap 2000 SXr with 2000 SRX ohlins ??
Check the parts lists on the reader on the opening page if the part numbers are the same for both sleds then they will work.Other wise you will have to measure them .
Your answer would be no, unless you switched everything on the front end. SRX ski stance is 40.9", travel is 7", and the installed length is 223mm, the SX-R is 42.0", 9", and 262mm. You have different trailing arms, tie rods, sway bar, and radius rods.
The caster is different on the SRX trailing arm. Which will change how your ski pressure and how the ski contacts the ground when switched.
