98 srx set up
srx98jj
lake milton , ohio
i need to beat a 700 mxz 2000 what should i do ,... it has a bender kit in it now , but i dont think it is working properly. engagement is around 3500 pulls hard though ,......... v force reeds cold air kit any help ?????
Get ahold of Turk he can put you in the right direction as well there are a plenty of setups in the tech section.Why would you worry about a 700 MXZ anyway?You should be able to walk away from it any time you please.
Engagement is a little low. sled likes to run at 82-8300 rpm at wide open throttle. Anything over those rpm,s you start losing hp.
