SRXtrafast
I still have some Klotz left in the oil res. Should I mix it w/ the bl mar or drain the tank and start fresh? Any suggestions?
SRXSex
SRXtrafast said:I still have some Klotz left in the oil res. Should I mix it w/ the bl mar or drain the tank and start fresh? Any suggestions?![]()
You can mix synthetics, just run the Klots low then add.
03viperguy
why switching? did the klotz do something you didnt like? wondering cause I just changed from yamalube to klotz
yamvip
just add it too it,if you drain be careful not too let it all out and get air in there,then you could be in for some problems.....
03viperguy
when I switched thos past weekend I went to my dealer and asked if they had any siphons for sale. kevin (one of the guys that owns and runs it) says hold on a sec. walks out back and comes back saying darrin (one of the mechs) will be out in a sec. I am thinking that is weird. but o well. then out comes darrin with the giant siphon thing (mityvac I think) and says here ya go. shows me how to use it and says it should work well. I was like "thanks I will bring it back as soon as I am done" I thought that was freaking awesome! no charge, and I wasnt even looking to borrow anyhting, I was going to buy! thanks to Pittsburg Motorsports in Pittsburn NH. those guys are awesome!
03viperguy
O yeah, moral of the story was I used a mity-vac to evacuate my oil
SRXtrafast
SRXtrafast
yamvip, I never gave it a thought about the air issue. Great input. thanks
Millinocket Rocket
i also just switched to blue marble this season, and i guess it's not synthetic-- it's a highly refined mineral oil. i still had some yamalube in the tank so i pumped out as much as i could with a lower end unit pump and refilled it with BM.
03viperguy
rocket, hows the BM working for you?
Millinocket Rocket
haven't noticed any performance gains yet, but they say you won't until a couple of tankfuls. i have noticed less smoke- except for cold starts, and it doesn't stink as bad as yamalube does.
yamvip
Same here,I did the switch.Only have 160miles this season though.Less smoke,doesn't stink.We will see how this oil is in time.
reply
I switched from yamalube to klotz. I didn't siphen anything. I started adding the klotz to the half of tank of yamahalube that was left. So far I have had no problems. why would you have to drain the old oil before adding the synthetic?
03viperguy
you dont have to, I just wanted to. have soem other sleds it could be used it, so I didnt want to wait to run down on yamalube.
vipertripplexxx
Buch of hype
Your not going to either, thats B.S.!!!! If they lie about the performance gains they probably are lying about the protection ability too! I noticed that they don't advertise film strength rating, not a good sign. Amsoil and Klotz both advertise there film ratings, and if marble was as good or better they would use it as a selling point, I'm certain of that. I used marble and was not impressed with the protection, smoke was gone though.haven't noticed any performance gains yet, but they say you won't until a couple of tankfuls.
yamvip
not impressed with the protection,how could you tell???
vipertripplexxx
I ran about 300 miles on the motor with yamalube for break-in, then switched to marble. In the two years I ran it smoke was low, and piston deposits/exhaust valve build-up were excelent, as advertized. No power increase was noticed, clutching stayed the same. I tore down the engine at 3300 miles, and exhaust side of rings on every cylinder showed alot of cupping. Also my cylinders were out of round .0012", Pissed me off bigtime, cause I have been taking down two strokes for alot of years and this is for sure excessive wear for 3300 miles! My Ski-doo had less wear at 6000 miles. There was minimal scuffing, which usually isn't caused buy the oil, it's particles and snowdust thats attributed to these type of markings. I run my machines fairly hot, but there were no signs of detonation/overheating, which would cause ring land warpage, so why the excessive ring wear? I believe the oil vaporizes at a lower temp than synthetics, hence the low smoke. My theory is that around the exhaust port you do not have the protection you would with a synthetic. In addition, a personal friend/race team that used to use marble, Had the same results, and has since stopped using this product.
yamvip
Hmmmm.......Very interesting,Maybe adjust the oil pump???
vipertripplexxx said:I ran about 300 miles on the motor with yamalube for break-in, then switched to marble. In the two years I ran it smoke was low, and piston deposits/exhaust valve build-up were excelent, as advertized. No power increase was noticed, clutching stayed the same. I tore down the engine at 3300 miles, and exhaust side of rings on every cylinder showed alot of cupping. Also my cylinders were out of round .0012", Pissed me off bigtime, cause I have been taking down two strokes for alot of years and this is for sure excessive wear for 3300 miles! My Ski-doo had less wear at 6000 miles. There was minimal scuffing, which usually isn't caused buy the oil, it's particles and snowdust thats attributed to these type of markings. I run my machines fairly hot, but there were no signs of detonation/overheating, which would cause ring land warpage, so why the excessive ring wear? I believe the oil vaporizes at a lower temp than synthetics, hence the low smoke. My theory is that around the exhaust port you do not have the protection you would with a synthetic. In addition, a personal friend/race team that used to use marble, Had the same results, and has since stopped using this product.
Any mods done to the viper?
yamvip
no none.
