Secondary shaft movement
viperino
Welland, Ontario
i noticed that there is some rotational play in the secondary shaft on my 97sx700....is this something that is normal for this sled or should i open up the crank case and have a look at the top gear.....
this problem is not to be confused with the play in the secondary clutch as i have the clutch off right now.
chain is a little loose, whens the last time you changed the oil and checked the tension?
please follow forum rules and only post one question in one forum. multiple posts on the same subject on multiple forums only clogg the server and slow the system down for all of us.
if your first post doesnt get a reply you can TTT, and bring it to the top. or move the thread with cut and paste to a more traveled area of the site. ski
