Power Inc. Pipes SRX
valin
Val Caron, Ontario
Has anyone run these pipes? What rpm are they supposed to spin at? Are they the same as the bender big volume pipes? How loud are they? Any info about these would be greatly appreciated.
Well, first day out with the Power Inc. Pipes. I'm not sure they have enough volume to run with the big bore. Bottom end and midrange has improved. Top end has decreased so far, but am over-revving (8600) for what these pipes want (8350). I am going to continue testing next weekend.
I have never seen a gain with aftermarket pipes on an stock srx. its sorry to say. Just run stock pipes unless you get any type of porting or a big bore, then i would suggest hauck howlers. that is my opinion anyways.
sxr-x, I am running a big bore. It was mentioned in the post. Also, the pipes do work on a stock motor, just not enough volume for the big cylinders.
power inc's and bender big bore pipes are the only one's that gain unless you go full race pipes.
True, but the bender's do not build power on a 700 motor. Been there, done that, got rid of them. Now i'm kicking myself for it. The power inc's are the only pipe that builds power on a 700 motor.
whoops.......didnt' know this was in the srx section. I just grabbed it out of my subscribed threads. Thanks for pointing that out YamerDown.
