How hard should i be setting the center bolt, when mounting my primery variator (the one in front with the wheigts and all)..?
Should i use locktite also?
Anything else i should know about mounting it?
BigMac
Ola said:How hard should i be setting the center bolt, when mounting my primery variator (the one in front with the wheigts and all)..?
Assuming you mean primary clutch...
No, don't use loc-tite. Put the clutch on and torque the bolt down to 85 ft-lbs (115 N-M), then loosen the clutch bolt and re-tighten to 43 ft-lbs (58 N-M).
BigMac said:Assuming you mean primary clutch...
Primary clutch, correct
Thank you
