Vmax540
What is the Stock 1990 Exciter secondary hole setting's ? I'm thinking A-1 50 degree's or any idea's on a good place to start ? Thanks !
Vmax540
Also, looking for offset and center to center.
Oregon Exciter
VMAX,
The standard setting is 50 degrees (A2), high altitude was 60 degrees (B2). The center to center distance should be 267-270 mm (10.5-10.6 in) Your offset should be 9.5-12.5 mm (0.37-0.49 in)
Hope this helps!
Hope this helps!
Vmax540
Thanks !
