SRXXX
- Nov 11, 2003
I pulled the carbs to clean them now the TORS is not letting me ecelerate past engagement. I think you can bypass it by plugging carb wires together but I want to know how to fix it???? Please help
thanks in advance!
Bill
thanks in advance!
Bill
RedlineViper
my viper did the same thing. the dealer thinks it's the sensor on the carbs that is causing it. i just looped the wires cause i didn't feel like replacing a sensor. worked great for me!
SRXXX said:I pulled the carbs to clean them now the TORS is not letting me ecelerate past engagement. I think you can bypass it by plugging carb wires together but I want to know how to fix it???? Please help
thanks in advance!
Bill
If you just had the carbs off to clean them then you probably put the throttle cable back on too tight. Try backing it off some.
