Show me a re-nik job for $100 and I'll give him a hummer. I shopped around a long time to get a good price, but it sure wasn't $100. I got 7,400 miles on my '01 SRX by the end of last year, and the cylinders were absolutely perfect inside. A ring job was all that was needed. I have seen many ski doo and polaris cylinders w/alot less miles that showed signs of wear, but the yamaha triples seem to hold up good. I made mine into a big bore, (using the wiseco pistons of course) and got 1 1/2 months out of it (a little over 3,000 miles). The compression went to crap, and sounds clattery. I was anal about everything I did in that motor, and even though it did make more power and got 13-15 mpg running fast, I believe the stock pistons w/ new rings would have been fine and still running long after my wiseco's peedered out, and yes they were coated on the tops and skirts. I will be tearing it down this week to see what the whole scoup is. My advice is, if you are happy w/the performance and don't need to spend a lot for the extra hp, stay stock bore and stay away from the wiseco. (Will It Seize Every Couple Outings?)
