Srx Max Rpm
JERSEYJOE
TUG HILL NY
For a 2001 SRX mostly stock with reeds and a canister what is the max rpm I should be hitting? Has W W W primary, stock weights, stock helix , green spring at 6/2
JOEY, 6-2 is stock !! DITCH EXHAUST CAN!! GO BACK TO STOCK. BIG WASTE OF POWER ON SRX. ANYWAYS ANYWHERE BETWEEN 8250 AND 8500. !! 3:16 (tony)
Srx Rpm
Tony: I am going to put the stock silencer back on , and I want to try the 50 / 40 helix you mentioned. Seems like my SRX is turning closer to 9000 at this time. By the way Dean is coming up to the hill on Jan 26 thru Jan 29 to ride with us. I know you don't do a lot of trail riding but you are also welcome at camp. I can squeeze about 9 guys.
Jersey
JOEY, I MIGHT TAKE YA UP ON THAT. I CAN,T GET ON VMAX4.COM ANYMORE. I AM IN LIMBO LIKE THE OTHERS. I GUESS ITS A AOL PROBLEM. ANYWAYS 9000 WAY TO HIGH. TAKE CAN OFF AND TRY SECONDARY IN 1-6. SRX,s CAN,T MAKE POWER OVER 8500 WITH STOCK CDI AND STOCK EXHAUST. TELL YA THAT CAN MIGHT BE PART OF THE PROBLEM TOO !! 3:16 (tony)
Srx Problem
I just order the Helix from Rich Motorsports ( 50 / 40 ). I am going to run the stock SRX weights, W W W spirng, 50/40 green seconday at 6/2 just like you told me to. Thqt Bender canister is way too loud so the stock can is going back on. Problem with VMAx4.COM? I have not tried to get on since Sunday. I am going to call Dean tonight and firm up about the Jan 26 to Jan 29. Place is small but we always get by and have a good time. It's in Barnes Corners. I am having problems with the APEX GT> It's way too soft and I am waiting for a spring. Also it's darting so bad I can't keep it on the trail. Ordered Bergstrom runners and the shim kit that will fix the problem. Since I fixed the power valves on the SRX it's running a lot stronger. I like it as much as the APEX!!!!!
Jersey
I GUESS WHATS HAPPEN IS GUYS THAT HAVE AOL RR CAN,T SIGN ON ANYMORE. I BELIEVE MYSELF, TOMMY HENNSHAW, DOUG AND LISA, BRAKES, etc CAN,T GET ON FROM OUR HOME COMPUTERS. AOL TECH TELLS ME ITS DEANS SITE. DEANS TECH PEOPLE TELLS HIM ITS AOL. POST FOR ME ON VMAX4.COM MY EMAIL ADDRESS IF ANYBODY HAS ANY QUESTIONS. THAT SRX SET-UP SHOULD WORK NICE. 3:16 (tony)
