SWEDE
Are these kits worth the 300 or so bucks?Do they backshift and pull better or is there a better way?Just wanted to know what the clutch master thinks,thanks in advance.
deekersrx700
Turk will tell ya what to run and it'll be cheaper than those kits.
I have never used either of those rollers.For a 01 sx-r change inner rivet to a 4.5 gram,get a used RX-1 helix (51/43)& that sled will be as good as it gets.
SWEDE
Thanks for the reply,is that a trail setup or all around?I ride probably 50percent winding trails and the rest off trail.Would that setup be good for that?
SWEDE
Thank you sir,cheap is good!
