Fasterblaster
I just bought a second Bravo for the kids. It seems to be in great shape but it is hard to start and occasionally stalls. I took the carb apart and cleaned it and replaced at "90" main, which is really small, with a stock "105" which is a little big for 4500', but really no change. Any suggestions?
Phazer
What do the plugs look like after you've pulled it over several times?
Fasterblaster
I'll check that out next time. I just keep pulling it over until it starts. It seems to like being choked when this happens, even if its already warm. You need to kick the choke off as soon as it fires and then sllllooooowwwwly give it some gas to bring up the idle or it stalls again.
