ponch1
- Jan 11, 2006
I am in need of settings for everything that is within the bowl area. I trying to get this carb put back together with no tech info.... I didn't take it apart but am trying to bring her back from the "brink"
Thank you!
Thank you!
ponch1
- Jan 11, 2006
I have the sno scoot (80 cc unit) running. BUT it will only run the choke on. Shutting off the choke, it will run for not quite 10 seconds then dies off like it ran out of gas.
I have the outside jet set correctly I believe and the float as well... I think so anyway. The main nozzle setting I am unsure of.
The ports on the carb throat have been cleaned and are clear.
Any input would be appreciated!
