ponch1
- Jan 11, 2006
I would appreciate any help with the carb settings information for a 1989 80cc Sno Scoot. Trying to get the machine put back together after someone else to it apart.
Thanks!
Thanks!
ponch1
- Jan 11, 2006
I have the sno scoot (80 cc unit) running. BUT it will only run the choke on. Shutting off the choke, it will run for not quite 10 seconds then dies off like it ran out of gas.
I have the outside jet set correctly I believe and the float as well... I think so anyway. The main nozzle setting I am unsure of.
The ports on the carb throat have been cleaned and are clear.
Any input would be appreciated!
2ooosrx
- Oct 2, 2004
- Gurnee, Illinois
- www.cbperformanceparts.com
Take your carb apart and clean it. Had the same problem had to clean them a couple of times.
Bruce
Bruce
