I`m out of ideas..
I am going to replace one of the clutch plates, in my primary clutch.. The one with the wheights mounted to it..
How the h*ll do i do this?? How do i split the clutch, to get to the plate?
The nearest solution i have thought of, and tried a little, is to try to unscrew the plate nearest the engine, because it looks like it is screwed on to the main bolt/cylinder or what i should call it.. But it was`nt moving at all, even though i used a long arm to force with..
Am i doing this wrong?
PLEASE help me, so i can try my new sled I have only been riding it for 1,5 hours since i bought it, so i am exited to get this back in.. hehe
bluewho
it takes a special tool dude!the clutch back is bolted to a table or bench and the tower is turned counter clock wise with a tool that goes over the 3 ramps and has a long arm to give her hell.
PowerValve-700
Unless you want to buy or make the tool, you're gonna have to bring it to your dealer. It'll only take them 5 or 10 mins.
ok, i guessed it was something like that..
i made a plate, bolted it to the back clutch plate, welded a 12mm bolt to it and used a long tube on the bolt, to twist the plate with.. but it sure is stuck...
My nearest dealer with this kind of equipment, is so far away that i have got to send the clutch to them in mail..
PowerValve-700
Apply lots of heat to the center area of the inner (fixed) sheave.
Millinocket Rocket
need to take a torch and heat the back side of the sheave- around the hole.
oops!- pv700 beat me to it.
bluewho
CLOCK WISE TO LOOSEN COUNTER TO TIGHTEN NO looking at the spring side?
Millinocket Rocket
bluewho said:CLOCK WISE TO LOOSEN COUNTER TO TIGHTEN NO looking at the spring side?
yes- that's correct
PowerValve-700
PowerValve-700
Also, clean the old loctite from the threads, apply new loctite and torque to 145 ft/lbs
Ok thanks guys..
I`ll try to heat it up, but it`s aluminium, so i have to be careful you know hehe
At least now i know i was doing it right, so i will give it another try before i send it away..
Thanx!
Ola
Thanx!
Ola
Heat and a long enough arm, sure was the trick!
Thanks everyone!
