press55
i have a 98 srx600 with two scored cyl. i would like to upgrade to a 700. has anyone tried this?
tomseal6
i havnt but, you can simply just put 700 cylinders, pistons, and heads on and change the jetting, you will also need the cdi box that goes to a 700 srx because the 600 has more timing advance.
press55
tomseal6 said:i havnt but, you can simply just put 700 cylinders, pistons, and heads on and change the jetting, you will also need the cdi box that goes to a 700 srx because the 600 has more timing advance.
do i need a 700 oil pump? will there be a big dif. in the 700 vs 600?
tomseal6
about 15HP difference. do not need oil pump, just adjust it to 700 specs if its not already. i believe its 21mm or 22 mm gap in the pump cable. pull up on it by the carbs and measure it with a caliper to see where its at right now... very easy to adjust.
press55
600 srx 700
do i need 700 heads would the 600 give me beter comp.tomseal6 said:about 15HP difference. do not need oil pump, just adjust it to 700 specs if its not already. i believe its 21mm or 22 mm gap in the pump cable. pull up on it by the carbs and measure it with a caliper to see where its at right now... very easy to adjust.
