Oil Light On, replaced sensor, still on.
MY VENOM
Southern NY
I searched the forum and no other suggestions other than the switch?
Has anyone ever found a short in the wire?
Thanks.
edit : its a 2000 srx 700
you will want to look at the wiring harness for rub through. You will prbably find an area of the harness under the motor that was worn through the wire insulation.
Do a search for wiring harness.
