03viper159
what should a viper run for normal exhaust temps, what would you guys recommend for a gauge setup
I ran a RacePak gage on my CPR Viper and loved it. My set up would run 1200/1250 at WOT, I personally would not want to run much hotter than that for any type of long pull but I will let the experts here decide what you can get away with.
Safe exhaust temps vary with probe placement. Get the piston wash perfect then check what temp that gives you, then you know the safe temp for your sled.
bluehammer
erik b is correct. Egts are only a guide to what your cylinder is doing. Get your wash right, look at the plug at the ground strap to see where the heat is, and then look at your temps on the gauge for reference. We run Digitrons.
03viper159
ok stupid question what do u mean by piston wash?
Do you guys really pull of youre head, looking for wash after every change of jets, or driving conditions??
mtnmx
- Jan 4, 2004
No you buy a good bendable light and rotate the piston down to the bottom and look for the babyfingernail size wash on the 10 and 2oclock position..this is only after a wide open burst of 30 sec...hit the kill switch and hold throttle open till stoppedOla said:Do you guys really pull of youre head, looking for wash after every change of jets, or driving conditions??
