maxwell
I am kind of embarassed to ask this question, but when it comes down to it, I will step up to the plate and ask it.
Which way dows the coolant flow? From the head to the cooler back to the bottom of the motor? Or bottom of motor, cooler, then to the head?
fluid flows up the motor and depending on what the thermostat tells it to do it either circles through the hoses and back to the pump or is diverted to the rh foot cooler and back around through the lh foot cooler and into the front heat exchanger then to the pump.
vipers cooling backward was a bonafied TY urban myth
