Straightliner
- Aug 10, 2003
Would like to find someone with knowledge in clutching Yamaha RX Warrior snowmobile.
First I am going to calibrate tac to see if tac is on. Then find out the rpms were she makes her power. Also would like to do some field test runs made with box stock clutching to know what I have. Then I will have an idea what to shoot for to run better then stock set-up. That is far as I can go on clutching a Yamaha. I have a complete Porta Tree Timming System ET 60ft ET Finish MPH Finish. If this were Polaris there would be no problem. Yamaha is Greek to me.
Need to find someone with lots of clutch parts helixs, weights,springs etc. I am not looking to buy clutch kit but to build one. I will buy what-ever it takes to make this sled run halfway right. May even consider going with 4 arm motor clutch. I was told it hits alot harder more squeeze on belt. Not looking to race sled but would like to get all the power to the ground possible. Sled is not here yet but should be in soon.
Have you tried our RX1 Forum????
Straightliner
- Aug 10, 2003
No, I am new to this Forum. But I will check it out.
