What to expect when I install clutch kit
BadAzzSRX
Southern Maine
Following the recommendation of others on this forum, I'm installing the following setup in my 99 700 SRX next week.
Primary
W-W-W spring, 8dn-20 w/ 4.5g in both holes, stock rollers & shims
Secondary
Green spring, 60 wrap, 51/43 Helix
Once I get this in I was wondering what my expected engagement and shift rpm will be, so I'll know it's working correctly. Is there a difference between shift rpm and max rpm......still learning the lingo.
Im pretty much in the same boat as you. I have everything that you listed except my helix is a 52/44. I was told that I might want to try the stock primary spring also.
