clutching 98 srx 700
blueflash
Paris Ontario Canada
fine tuning the clutch 98 srx 700
Okay guys I want to start from the top here so I dont get screwed up on what kind of set-up to run here. If I have a
52/44 helix--8dn-20weights what size of rivets do I use and what springs do I use???? :o| I have 192 studs now with adjustable weight transfer rods so I hook up pretty good.
I know that I should use a green secondary but would you guys use the WWW primary spring or stock primary. Would you guys use 4.5 gram rivets also in both holes.
for the 10,000th time, 4.5 rivets in both holes, white/white/white spring, 8dn-20 weights. your helix will be fine.
okay thanks. I just wanted to double check that everything will be fine because my helix is a little bit different.Im kind of paranoid when It comes to my sled. :o|
