2002 viper advantage helix what hole ?
quebec#1
montreal/Quebec/Canada
I bought a 48/40 advantage helix and a yamaha green spring, My question is what hole should i set the secondary spring in ? It has four on the helix.
my clutch kit consist of the following that Turk recommened a 48/40 helix. Run 4 grams heel, 1st hole empty & 3-4 grams tip ( heelclikers )with the red primary spring & use a green yammie secondary spring at 60 degree twist.
So i think i see your point , on the helix it has for holes #'s 0 ,3,6,9, So if i wanted a120 twist i would go for 6 & 6 ? How would get a 70 twist 6 on the helix 1 on the secondary ?
