juggs
- Jan 16, 2006
hi all new here
have a 89 srv there is no spark or head light when it is pulled over.. the outer coil (plug wire coil ) has been replaced.. is there a lighting coil and a exciter coil in the older yamaha`s ? does the exciter coil produce all spark ? do i need to pull the motor to get the fly wheel off? or is there enogh room to get a fly wheel puller in there between the frame thanks for any tips and suggestions
srv540
It would be easier if you did pull the motor! For all your SRV meed head over here for help!
http://srv540.proboards80.com/index.cgi?
