Can you tell me if the sxr trailing arm is the same of the srx???
They should be the same. The only difference in the part number is the prefix. SX is 8CR and SRX is 8DF. Your dealer would certainly be able to tell you
:Moon:
Yes the caster is different, they are identified by the letter on the front by the radius rod mounts
Then you got the long travel arm that has a a caster of 25.5 degrees. You need one that has 23.5 degrees... Don't know whether the '97 - '99 SX is interchangable with the SRX... if so the only difference would be color.
fortress said:
so, its for the sx and srx!! is the sx the same suspension has sxr! i'm confuse
i did buy the left trailing arm from a 2001 sxr
well, The 2001 sxr should have trailing arm ID mark of 'R' (9" travel, 42.1" stance). The SRX should have a 'V' ID mark (7" travel, 40.9" stance). That would make the differnce of 2 degrees of castor. Will it fit? Yes. Is it the same? No. The castor difference will probably make the sled want to pull to one side. I don't know how much. It will work in a pinch but probably shouldn't stay that way.
i did buy the trailing arm from ebay.. its too late to cancel,, i'm dumb, ,i was sure it was the same thing. .these used srx trailing are very rare!! :((
