Hey everyone
i got a new Yamaha 3/4 team jacket and i got dirt on the seleve right on the white Yamaha and i need to wash it. On the Jacket itself it states that you can't wash it or dry clean it. It says to hand wash with a mild detergent. Has anyone had stains and hand washed and it came clean if it did what did you use. Any help will be much appreaited
n2oiroc
good question. i have a reima premier jacket with grease on the red part of the sleeve. i heard you need to use an additive when you wash gore tex so the pores dont close up.
madmax
Guest
i would use some shout or some sort of stain remover on the white let wash it cold and hang dry it, but before you use the stain remover do a little test on some white in a not so noticeble place to see if it changes the color, good luck
kysledneck
Oxy clean! Stuff is awsome! I have a Yamaha FXR jacket I am selling looked it over had a stain on it Put the oxy on .... GONE! also I bought a Tek vest on ebay guy used it racing outside the jacket fairly dirty when I got it looks great now after the oxy clean & a brush!
shortstop20
- Mar 6, 2005
- Stickney, South Dakota
- www.snowmobilefanatics.net
I agree!! Oxy Clean RULES!! If that doesn't work, mix the Oxy Clean with a little Greased Lightning!
If it's gore-tex, DO NOT dry clean it. Gore-Tex can be washed, but not dry cleaned.
Thanks guys i'm going to try the Oxyclean and i will post the results
