billjd
Last night I was putting the finishing touches on my SRX after the deer accident and thought I would just top off the Oil in the case that we ever get snow, by accident I grabbed some 20w-40 oil and put a 1/4 cup or so in before I realized I had grabbed the wrong oil.
Should I drain it out or could I just fill it up and run it?
Thanks Bill D
Thanks Bill D
shortstop20
- Mar 6, 2005
- Stickney, South Dakota
- www.snowmobilefanatics.net
If it was only a 1/4 cup I would just say leave it as is. I don't think it would hurt anything.
woolyviper
used to run 10/30 in my yamaha motorcycle as injector oil back in the day - 2 stoke cost too much when you're 12.
billjd
I spoke to my dealer and he said to drain it, 1/4 cup would = rebuild. Going to be a pain in the butt but I guess no reason to take a chance.
Thanks Bill D
Thanks Bill D
Exciterfan
You should be able to syphon it out without too much trouble. I'd try that before taking thinks apart. It'll just syphon a little slower than gas!!
clharris
it won't hurt a thing , if worried mix a little 2 stroke oil in the gas
It shouldn't hurt any thing i've done that before too with no problem it just mixes with the 2 stroke oil, BUT...... if you can get her outa there try too.
billjd
I'll try to syphon it out the best I can and hope for the best. Thanks for the help.
Bill D
Bill D
billjd said:I'll try to syphon it out the best I can and hope for the best. Thanks for the help.
Bill D
Yup...good luck!!!
caravanman
woolyviper said:used to run 10/30 in my yamaha motorcycle as injector oil back in the day - 2 stoke cost too much when you're 12.
When I was 12 and had no money for 2 stroke oil, I used ATF in my Suzuki TS 100!
Siphoning the oil won't work you. You will need a suction gun or vac kit that is used for bleeding brakes. If it were me I would just fill the oil tank up with 2 stroke oil and ride. 1/4 cup won't matter at all.
suction gun @ hardware store $20.00 = rebuild $?????? Id go for the suction gun.
clharris said:it won't hurt a thing , if worried mix a little 2 stroke oil in the gas
Ditto on mixing 2stroke oil with your gas...
shortstop20
- Mar 6, 2005
yamahinn03 said:suction gun @ hardware store $20.00 = rebuild $?????? Id go for the suction gun.
How can 4 stroke oil blow up your sled? Mix 2 stroke gas in the gas tank and if anything you'll have too much oil mixing in with the gas. Last time, I checked too much oil can't blow up your sled.
caravanman said:When I was 12 and had no money for 2 stroke oil, I used ATF in my Suzuki TS 100!
Siphoning the oil worked just fine for me this fall when I emptied the tank to change to synthetic. Used fuel line and the sled was in a heated garage so that may be why it worked. Used a coat hanger to get the line near the bottom(it wanted to curl up). Worked mint.
SRXPete
My dad used oil so cheap it just had the number 30 on it (30 wt 4 stroke engine oil). It was used in the 1972 Ski-doo 300 Olympique and 440 Nordic for the entire lives of the sleds and they lasted until 1987.
Steven DeMarco
- Feb 16, 2004
if you are going to siphon the tank try a turkey baster. 3 bucks at any grocery store. you can put a hose on the end of it to get down deep.
i assume youre refering to the the injection oil? remember that injection oil has added properties to make it flow at low temps. ever here your car rattle at low temps until warm? get it out of there!
woolyviper
1/4 cup = 2 ounces
full reservoir = 102 ounces
2 ounces = 2% of the total
I would bet you could burn 2% orange juice and it wouldn't matter.
woolyviper said:1/4 cup = 2 ounces
Hmmmmmm.... That would give it a nice orange smell, and clean everything out at the same time. You may be on to something.
shortstop20
- Mar 6, 2005
My point exactly.
