Zion Lion
- Sep 18, 2005
02 Viper has been running well, just serviced. Pulls over in pull or two cold.. running heated carbs in 25f weather for an hour or so.. stop the sled, shut if off.. takes several pulls, and sometimes slightly opened throttle to start ... thoughts?
they all are like that, its the flatslide carbs, all you have to do is barely crack the gas and pull the rope on a srx or viper and it will start in 1 pull when warm, very common
Exciterfan
The SXR is the same. Once she's been running, you have to just crack the throttle and pull her over.
Cheers,
Exciterfan
Cheers,
Exciterfan
Apexpredator
test...
I thought this was annoying at first but now I think its cool, because with the throttle cracked the viper roars to life while the othes in the group just start all lazy like
