My srx 600 overrevs, about 9000-9200rpm.
I made race logic porting,cut heads .010 and change my inner rivets from 3.1 to 4.5. The change of rivets made almost no difference at all, maybe it load the engine a little more at low speeds. I have a 1.5" track (camoplast 9803) everything else stock. Suggestions? rx-1 51/43 helix?
8bu-00 weights, 1st hole empty 2.4 gram rivet in tip, 45/39 helix silver secondary spring at 60 wrap. 51/43 won,t change rpm,s.
Thanks Turk, will I still have a good backshift with this setup?
