daverx1 said:I am rebuilding a 97 700sx. I need tourq values for the:
Head bolts/ nuts-two steps;first-9.4 ft.lb;second step-18 ft.lb
Cylinder base nuts/ 20 ft.lb
Crank case bolts that hold the case halves together/two steps;1st 9.4 ft.lb,2nd 19 ft.lb
Exaust manifold/ 19 ft.lb
Reed valves/ 10 ft.lb
flywheel nut/ 61 ft.lb
clutch bolt/ two steps torq to 87 ft.lb loosen up complety re torq to 43 ft.lb
Thanks in advance for any help!
