BAD BACKSHIFT? What could cause?
xsivhp
Eau Claire, WI
When I'm riding on trails 30 + mph, when I come to a stop sign, falls flat on its face until it goes back to idle, only happens in lower speed situations.
I don't think it's back shifting quite right - any ideas?
if its a situation where it wont respond to any throttle until it gets back to idle, it may be your T.O.R.S is kicking in....if its the tors you need to loosen off your throttle cable a bit
It ran perfect for about 30-35 miles and then started bogging after that.
The TORS was acting up when I first got it back together, thought I had it fixed. I'll look into that and let you know what I figure out..
thanks!
if you hadn't changed anything prior to this problem and it was running correctly before, I would say more twist on the secondary spring is just a bandaid solution and you have other issues that may need to be dealt with in the future..
good luck..
