Fox Shocks
russ
tinley park , illinois
HAS ANY TRIED THE FOX FLOAT SHOCKS ON THE FRONT OF THERE
VIPER . IM THINKING OF GIVING THEM A TRY PLUS THEY CUT OFF SOME
WEIGHT . IM JUST NOT SURE IF I SHOULD SPEND THE 800.00
IM A 170 LBS AND THE FRONT END IS JUST KILLING ME
THANKS
RUSS 03/VIPER
DOGGIEMALE@YAHOO.COM
:die: CAT KILLER
I think that the floats are now $695.00 a pair. Why not have your stock KYB's revalved if they are killing you? Contact Bruce at Pioneer Perf. in NY. He will fix you up on the rebuild. Also IMO. KYBs are better units than Fox.
2datrl
Fox Floats
Would the phazer floats work. I know they didnt have the phazer then, but how about the fitment?
I believe the phazer upper mounts are eyelets, not clevis, so if that is the case then they wont work on the viper.
earlier this year Mountain Perf and Pioneer Perf had them on sale for $600. if you wait till next spring they might have the same deal.
i have some fox floats from a yamaha four stroke that i may part with. i'm looking to upgrade from regular floats to the evo's. just in case your looking for some. i am doing the same thing, except on a srx bulkhead. works much easier because it doesn't have the clevis mount.
If your willing to spend 800 bucks you might as well buy some real shocks OHLINS that is.Been told the fox floats belong on a BMX bike.
