trick569
will the new wrist pin slide in or is it pressed in and still need help on the oil cable adjustment......
B2SO
- Aug 18, 2003
new wrist pin will slide in , it might need a gentel tap , but no press needed..
Your wrist pin should slide in. As for your oil pump, while holding your throttle wide open pull your oil pump cable out , the top edge of bottom half of the adjuster should center up on a dot on the top half. I'll try to get you a picture. There is also a millimeter measurement for between the two halfs when pulled apart which is 21mm or 7/8", if you use this method you do not hold the throttle open .
trick569
Thanks guys!!! still not sure where to measure the 21mm from is it the adjuster up from the bracket ///bracket to the adj nut 21mm???
It will slide right in, did mine 2 weeks ago.
it's the distance of the space, when you pull the adjuster part of the cable apart. the lowest part of the upper section and highest part of the lower section
Junior
if you have trouble with the wrist pin, get a piece of threaded rod and a 15mm deep socket, run the threaded rod thru the socket and the middle of the wrist-pin, thread a nut on on the both sides. then tighten the nut at the end of the socket, this will pull the wrist pin out "straight" takes a couple more minutes, but if you're having trouble, it works every time. (especialy handy when the ring land is collapsed, or there's shrapnel that has deformed the pinhole.
Looks like this;
and
and
trick569
Thanx A Bunch
You guys are awesome thi=s site is too much I've only been a member for three days and have purchased everythiong I could possibly want ( for now!!)
And the support is overwhelming !!!!!! Thanks too you alll I'm going to tell all my friends................
LOL.......you do that.
yamaholic22
Junior said:if you have trouble with the wrist pin, get a piece of threaded rod and a 15mm deep socket, run the threaded rod thru the socket and the middle of the wrist-pin, thread a nut on on the both sides. then tighten the nut at the end of the socket, this will pull the wrist pin out "straight" takes a couple more minutes, but if you're having trouble, it works every time. (especialy handy when the ring land is collapsed, or there's shrapnel that has deformed the pinhole.
You been reading my methodology notes junior? lol That works like a charm.
Junior
lol, I thought I came up with that.
to good (and simple) an idea to go unnoticed for long i guess.
