mhhbolson
- Feb 26, 2004
Hey boys can anyone gimme a good site for tech help on cats. A guy brought me a 1995 zr580 efi. it hasn't got any spark. I check all the resistance readings on the ignition components. Everything was up to spec. problem is being a Yamaha sled only tech I know shit about EFI. Do any of you know if the efi box can cause a loss of spark. or if there are any other switches i should bypass turn the key and it primes the rail, but no spark
thanks
thanks
Go to hardcoresledder.com. That is a major cat info site.
sledderbob
don't want to turn this into a cat forum but check your ground wire from the CDI box. Its best to run a seperate ground wire directly from the ground on the cdi to the battery. Those machine were known for bad ground connections. ACQ problem (Arctic cat quality)
