95-vmax
- Jan 23, 2006
hey..
i just bought a 1995 vmax 600cc with twin pipes..
just wondering if anyone has specs on this sled..
hp
top speed
stuff like that..
thanks
hp
top speed
stuff like that..
thanks
I would think that the twin pipes should bump it up over 100 Hp, but I couldn't tell you exactly. I believe they were around 95 stock.
Stock, they would hit 90-100 Mph on the dream meter.
I have a stock piped 95 and I can get between 90-95 on an open smooth lake.
I've had mine('95) to 100mph all stock!!!!
yammiman
I've had three of them over the years - they all run right around 100 mph stock - be careful of the twin pipes - I've never seen one stay together once they are piped - touchy motor to hop up - do you know whose pipes they are?
95-vmax
- Jan 23, 2006
what grade of gas should i use??
87 89 91 94
thanks
87 89 91 94
thanks
95-vmax said:what grade of gas should i use??
87 89 91 94
thanks
I'd use at least 89,,and make shure you keep an eye on your plugs
so you don't burn down!!!!!
yammiman
I always keep a little race fuel around for all of my high performance stuff - a 25 to 50% mix with pump gas just to be safe - depends on how it is jetted - that is why it would be good to figure out who's pipes are on it, then get a hold of the spec sheet for them - the old saying "an ounce of prevention!"
sandmanmike1
I run strictly mid grade in mine and see no benefit with premium. How many miles are on it. I would re ring it around 3000-3500 miles.
