Waterfoul
I need the casting number off the side of the clutch side cylinder.... quick so I can order the part and have it on Wednesday so I can ride this weekend!!! Should be an 8CR ?? number cast right into the jug. Easily visible on the side with the hood up.
Mike
Mike
800
If you're buying a used cylinder, it needs to be a 600 with triple exhaust ports and a 4 bolt reed cage, I believe it is an 8CR, but the reed cage is a definate ID, the 94-96 600s were 6 bolt, and didn't have triple exhausts
Waterfoul
getting one from Millenium in Wisc.... but he want's the whole number off the side... 8CR ??... I just want to be sure.
Waterfoul said:I need the casting number off the side of the clutch side cylinder.... quick so I can order the part and have it on Wednesday so I can ride this weekend!!! Should be an 8CR ?? number cast right into the jug. Easily visible on the side with the hood up.
Mike
My '98 says "8CROO" ....pto side
Waterfoul
Yup, that's it. Thanks!
Waterfoul
Dude, no water.... makes me have to pizz... call me Foul! LOL!!!
It's what most of my boater buddies call me.... Waterfoul is the name of my boat.
Waterfoul said:It's what most of my boater buddies call me.
What then Water or foul.....LOL
Get your cyl. orderd ...."FOUL".....LOL
