Yes, its about rising handlebars... Again..
Going from my 2" block, to a 4" articulate, fly or similar, and need longer throttle cables.. Oh, and a brake line..
I have done som searching on this site, but not got the answers i am looking for..
-How much longer are the Viper Mountaing cables and brake line than my stock ones?
-Does the Viper M also have two cables on the throttle thumb, like my 02 viper?
-Do they fit my sled without modifications?
Any hints where to buy the cable/cables and brakline cheap, that are willing to send it to me in Norway? Parts in Norway are expensive, and then some...
trick569
got cables
I went with fly bars and 41/2 riser articulated got cables from mountain performance (there not on the site you must call) Cheap!!!
richierich
longer oil=$20
longer throttle=$17
longer brake line=$55
shipping to norway=$25
longer throttle=$17
TimeBomb
so to go to a 4" riser, the mt. viper cables work?
yamaholic22
yes sir!
Mtnviper
I used a 05 Mtn Viper throttle cable on my 02 with 4" of pivot riser.
The 05 cable is about 2 1/2" longer. It is a single cable into the throttle block, with a splitter approx half way down. One end goes the the carbs, the other to the oil pump.
The end that fit's into the throttle lever block, is a different shape and diameter then the stock 02 cable's. So I had to drill out the throttle block slightly to make it all work. Now that it's all done, it works well. But to be honest, it was kind of a pain in the arse to do. If I was to do another one, I'd just get longer cables from MPI or Rich, and be done with it.
I'm still using the stock brake hose. Just did some re-routing and it's working fine.
I dont use a parking brake cable. I went with MPI's weight-less parking brake kit.
