putting back helix on secondary, help
srx600
Madawaska, Maine
If I were to take my helix off, the spring would come off right, but my real question is what do i have to do to put it back on? Do I have to twist the spring a certain degree or something? if so How do i check what the degree was before and match that degree when putting it back on?
When installing the helix you need to twist clock wise enough to get the bolts to line up. There are numbers on the helix and clutch to set the spring in to set your degree of twist. If you want to keep the twist the same note the position on both before you remove. The info is in the tech page.
