BadAzzSRX
I just installed my green secondary spring and wrapped it to 60 (3+3). Once I aligned the holes I only had to turn it a little bit (adding tension) to get the bolt holes to line up. I expected it to be rather difficult to do, but was actually easy. My question is did I wrap it enough?? This was my first install.
viperino
sounds like you've done it right...60 isnt much tension in the secondary....im not sure about the srx(i have a viper) but i keep mine wrapped at 70(6+1)....if u try 6and 1 you''ll notice that it will put up more of a fight to get lined up
redsnake3
dont you have to go past the first thread and on to the second for the secondary?
terret725
u just pop the springs in the hole and twist it clock wise till it lines up with the bolts.
redsnake3
damn i always went past the first to the second
redsnake3
sooooo, i think i have some work in for me
vipertripplexxx
Snake, I see you've changed your avitar....I like it!!!! Those are SAWEET!
blueflash
best avitar ive scene on here
BadAzzSRX
Thanx guys, it went just a little too easy, so I thought I would ask.
Snake, I second the avatar, nice work!!!!!!!!!!
redsnake3 said:dont you have to go past the first thread and on to the second for the secondary?
Red your Avatar's Hot....lol
vipertripplexxx
redsnake3, What happened to the avitar? BRING IT BACK!
