quebec#1
I have a set of heel clickers 4grams heel nothing in the middle and 3 on the tip for a 2002 viper. Would increasing weight on the tip increase my rpm's ?
You would need to decrease your weight on tip.
You must lighten the tip to increase rpm,s. the heel will also slightly raise rpm,s but the tip will make a larger difference. Less weight = slower upshift=more rpm,s.
quebec#1
This is my set up :G 48/40 , 4 grams heel, 1st hole empty & 3 grams tip with the red primary spring,a green yammie secondary spring at 60 degree twist.
It work great but top speed and rpm's are too low for my liking, Im only reving at 8300 to 8400 and would like it to be more like 8600.
Srxspec
Your #1 performance shop!
Take 2 of your washers out of the tip of the weights and it'll be very close.
