RXW LE
Hello all
want to install 1,5" lug ripsaw track on stock 2000 SRX, do I just put it on or do I have to change anything, etc. drivers???
Ernie
Ernie
No problem fitting the 1.5" Ripsaw in your SRX. I've installed one in my SRX. For clearance will you need to remove the front heat exchanger protectors and also the tunnel protectors. You can use your stock 9 tooth drivers.
RXW LE
Thanks for your reply. So if I want to keep the tunnel protectors, I will have to change to 8 tooth drivers? Is that it???
Ernie
Ernie
Nope, you still need to remove them. With 8 tooth you will be able to keep the front exchanger protectors only.
Maddogs700srx is right on the money.Maddogs700srx said:Nope, you still need to remove them. With 8 tooth you will be able to keep the front exchanger protectors only.
