SRX M10
What gearing will get you back to the 9 tooth ratio on an srx? Thanks.
with 8 tooth drivers your at a 1.86 with stock 23/38. stock 23/38 with 9 tooth drivers is a 1.65, you would need a awfull big top gear and little bottom to get there and chain length would play a factor, closest you can get by my scale is a 24/37 gear combo thats a 1.74 ratio with 8 tooth drivers. You could get there with a 24/35, but im sure would need a custom chain length. The 1.74 ratio is good all around gearing, decent drag racing and good topend, your not gonna set a top speed world record but should still do over a 100mph.
