Tach interchangibility
deepnsteep
Gillette, Wy
I was wondering what Yamaha tachs will work with what models?? I have a 98 MM 700 and got a raptor lite hood. I need the >2000 style tach...separate tach/fuel gauge. Will an SRX 600 or SRX 700 both work for the MM?? Same with a 600 SXR....
Thanks!
deep
Yes the're all the same. You'll need a different wire harness that goes from the stator under the engine to the instruments if your changing from the single cluster to the individual gauges. I know there's a way to jumper the original harness but a newer harness is the cleanest and easiest way to do it.
I think you just need the hood harness. I jumpered my its reallllllly easy. Basically there are more back lights on the dual gauges than the pod.
Damn Jwiedmayer you are correct sir. I forgot the hood harness was seperate, I was thinking it went from the instruments to the connection near the stator.
