Where do you usually have your limiter straps set for trail riding?
iahacker
When I had the original SRX shocks on, I let them down to gain weight transfer. Can't tell you the measurment. Went through 3 sets of slides last year in 700 miles.
This year I have Viper shocks on the back and raised the front 1". I allways run my suspension soft cause I like the ride. This year I've been tightening them up. The softer rear shock and set up transfers better and have been trying to keep the front down. When the back is lifted with the grab bar, the rear wheels raise about 3" before the front of the skid comes off the ground. Haven't put any slides on this year in 400 miles so far.
Just what I do.
Good luck.
Just what I do.
Good luck.
pull the strapes up to 42mm from top of bolt to bottom of brkt
